[petsc-dev] configure failed after update of OSX
Tue Jan 28 18:16:59 CST 2014
On Tue, 28 Jan 2014, Sean Farley wrote:
> balay at mcs.anl.gov writes:
> >> mfadams at lbl.gov writes:
> >> > Oh yes.  I had a use-make=make commended out. I uncommented it and its
> >> > seems to have gotten MPICH installed.
> >> There is a newly (only a few days old) updated mpich port that I now use
> >> with my petsc install.
> > This is not really a fix - as the 'gmake' error will pop up with petsc
> > part of the build aswell.
> False. It works perfectly fine here.
That doesn't mean it woud work for Mark. Previously [a few months
back] Mark had the same issue - and you've responded that you couldn't
reproduce it.
> >> > On Tue, Jan 28, 2014 at 1:26 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> >> I'll have to check back my e-mail archive - but I think
> >> >> '/opt/local/bin/gmake' is broken. Don't you have /usr/bin/make?
> >> >> I thought petsc configure prefred /usr/bin/make - if it was found.
> >> >> One more -ve for macports..
> >> There is a fundamental problem with using two stacks. Similar, I think,
> >> to trying to simultaneously link to libc++ and libstdc++. It is just
> >> asking for trouble.
> > I'm not sure how this is causing gmake 'internal' error..
> It doesn't necessarily mean that gmake is broken but could be something
> mismatched. I can't tell without the internal logs.
> Though, I recommend that Mark not use any --download options through
> petsc because those packages are now in MacPorts and mixing two stacks
> is just asking for trouble.
So - unless Mark is also using 'macports' install of PETSc - he is
asking for trouble? [otherwise he can easily end up mixing these
exteranlpackages from macports - and build petsc with native OSX
compilers - so will end up mixing stack anyway?]
Satish
