[petsc-dev] configure failed after update of OSX
    Sean Farley
    sean.michael.farley at gmail.com
    Tue Jan 28 17:34:54 CST 2014
balay at mcs.anl.gov writes:
> On Tue, 28 Jan 2014, Sean Farley wrote:
>> mfadams at lbl.gov writes:
>> > Oh yes.  I had a use-make=make commended out. I uncommented it and its
>> > seems to have gotten MPICH installed.
>> There is a newly (only a few days old) updated mpich port that I now use
>> with my petsc install.
> This is not really a fix - as the 'gmake' error will pop up with petsc
> part of the build aswell.
False. It works perfectly fine here.
>> > On Tue, Jan 28, 2014 at 1:26 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> >> I'll have to check back my e-mail archive - but I think
>> >> '/opt/local/bin/gmake' is broken. Don't you have /usr/bin/make?
>> >> I thought petsc configure prefred /usr/bin/make - if it was found.
>> >> One more -ve for macports..
>> There is a fundamental problem with using two stacks. Similar, I think,
>> to trying to simultaneously link to libc++ and libstdc++. It is just
>> asking for trouble.
> I'm not sure how this is causing gmake 'internal' error..
It doesn't necessarily mean that gmake is broken but could be something
mismatched. I can't tell without the internal logs.
Though, I recommend that Mark not use any --download options through
petsc because those packages are now in MacPorts and mixing two stacks
is just asking for trouble.
