[petsc-dev] configure failed after update of OSX
    Satish Balay
    balay at mcs.anl.gov
    Mon Jan 27 23:27:37 CST 2014
I've generally recommended hpc.sourceforge as its simple, easy to
install and has worked for me for a long time. [Uninstall requires a
bit of effort though..]
Sure - if one needs a bunch of packages including fortran -
homebrew/macports would be the way to go.
We've had quiet a few maint issues with macport conflicts - and Sean
had been trying to resolve some of them within macpors. [And helping
folks here on this list]
Previously Homebrew had gfortran-4.2. But that was a buggy version and
broke petsc f90 related functionality - so I didn't recommend it. But
now I see gfortran-4.8 in homebrew - so perhaps it will work better
now.
Satish
On Mon, 27 Jan 2014, Aron Ahmadia wrote:
> Mark,
> You don't have any surprises in your configure file.  I'm not surprised
> that your MacPorts install broke, we saw pretty terrible breakage across
> the Scientific Python community, although I think Homebrew weathered the
> update pretty well.
> I'd suggest following Sean's instructions so long as you're happy with Mac
> Ports.  The most important thing is getting your compiler stack sane, and
> unfortunately when you're compiling Fortran on OS X, you're going to have
> to deal with a half-crazed stack no matter what you do.  See Geoff's
> excellent summary on SciComp for future Fortran compiler options:
> http://scicomp.stackexchange.com/a/2470/9 -- MacPorts is a reasonable
> choice here.
> HashDist's main purpose is in helping scientists specify a software stack,
> then reproduce it elsewhere.  It looks to me like PETSc is actually
> satisfying most of your stack, and the only place where you need a little
> help from MacPorts is the Fortran compiler, so I think HashDist would be
> overkill for your needs here.
> Cheers,
> Aron
> On Mon, Jan 27, 2014 at 6:19 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > Sean, I seem to need to reinstall macorts.  I ran this:
> > *Edit:* A binary installer for Mavericks (for the 2.2.1 bugfix release)
> > is now available:
> > https://distfiles.macports.org/MacPorts/MacPorts-2.2.1-10.9-Mavericks.pkg.
> > And it created a MacPorts directory in Application but this just a few
> > apps but no 'port' command.  Any idea what is going on here?
> > Thanks,
> > Mark
> > On Mon, Jan 27, 2014 at 11:44 AM, Sean Farley <
> > sean.michael.farley at gmail.com> wrote:
> >> bsmith at mcs.anl.gov writes:
> >> >   I think resolved it by getting rid of some stuff that macports put in
> >> maybe
> >> I just *completely* revamped the mpi ports in macports and would like to
> >> know if these types of problems still exist.
> >> >   MPICH or libtool assumes certain files are there if other files are
> >> there (without checking for them)
> >> >    Barry
> >> > On Jan 27, 2014, at 10:36 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> >> On Mon, 27 Jan 2014, Jed Brown wrote:
> >> >>> Mark Adams <mfadams at lbl.gov> writes:
> >> >>>> It seems to want /opt/local/lib/liblzma.la
> >> >>>> I do have /opt/local/lib/liblzma.a
> >> >>> There is no explicit reference to liblzma in either PETSc or MPICH.
> >>  Can
> >> >>> you send PETSC_ARCH/externalpackages/mpich*/config.log?
> >> >> Ah - perhaps its a buggy libtool. Presumably its picked up from
> >> >> /opt/local/bin/libtool - aka macports - and you have a broken macports
> >> >> install.
> >> >> Satish
