[petsc-dev] configure failed after update of OSX
Mark Adams mfadams at lbl.gov
Mon Jan 27 17:19:18 CST 2014
Sean, I seem to need to reinstall macorts.  I ran this:
*Edit:* A binary installer for Mavericks (for the 2.2.1 bugfix release) is
now available:
https://distfiles.macports.org/MacPorts/MacPorts-2.2.1-10.9-Mavericks.pkg.
And it created a MacPorts directory in Application but this just a few apps
but no 'port' command.  Any idea what is going on here?
On Mon, Jan 27, 2014 at 11:44 AM, Sean Farley <sean.michael.farley at gmail.com
> wrote:
> bsmith at mcs.anl.gov writes:
> >   I think resolved it by getting rid of some stuff that macports put in
> maybe
> I just *completely* revamped the mpi ports in macports and would like to
> know if these types of problems still exist.
> >   MPICH or libtool assumes certain files are there if other files are
> there (without checking for them)
> >    Barry
> > On Jan 27, 2014, at 10:36 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> On Mon, 27 Jan 2014, Jed Brown wrote:
> >>> Mark Adams <mfadams at lbl.gov> writes:
> >>>> It seems to want /opt/local/lib/liblzma.la
> >>>> I do have /opt/local/lib/liblzma.a
> >>> There is no explicit reference to liblzma in either PETSc or MPICH.
>  Can
> >>> you send PETSC_ARCH/externalpackages/mpich*/config.log?
> >> Ah - perhaps its a buggy libtool. Presumably its picked up from
> >> /opt/local/bin/libtool - aka macports - and you have a broken macports
> >> install.
> >> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140127/d12301e8/attachment.html>
