[petsc-dev] Possible bugs when using TS with ViennaCL
Karl Rupp
rupp at mcs.anl.gov
Sat Jan 25 15:14:35 CST 2014
Hi Mani,
could you please send me the code including the error checks?
Thanks and best regards,
Karli
On 01/25/2014 10:07 PM, Mani Chandra wrote:
> Hi Karl,
> I now checked the error flags of all petsc functions in all functions. I
> also recompiled petsc with debug. Here's the report:
> Case 1) Still works. All good.
> Case 2) This is the case with ComputeResidual using VecGetArrays but
> with DMSetVecType(da, VECVIENNACL) and DMSetMatType(da, MATAIJVIENNACL).
> The flags don't show any errors. *The programs proceeds smoothly but the
> solution is wrong even though SNES is converging.*
> Case 3) This is the case with ComputeResidualViennaCL using
> VecViennaCLGetArrays with and without DMSetVecType(da, VECVIENNACL) and
> DMSetMatType(da, MATAIJVIENNACL). In both cases I get the following error:
> [0]PETSC ERROR: TSComputeIFunction() line 676 in
> /home/mc/Downloads/petsc/src/ts/interface/ts.c
> [0]PETSC ERROR: SNESTSFormFunction_Theta() line 284 in
> /home/mc/Downloads/petsc/src/ts/impls/implicit/theta/theta.c
> [0]PETSC ERROR: SNESTSFormFunction() line 3499 in
> [0]PETSC ERROR: SNESComputeFunction() line 2089 in
> /home/mc/Downloads/petsc/src/snes/interface/snes.c
> [0]PETSC ERROR: SNESSolve_NEWTONLS() line 175 in
> /home/mc/Downloads/petsc/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: SNESSolve() line 3812 in
> [0]PETSC ERROR: TSStep_Theta() line 183 in
> [0]PETSC ERROR: TSStep() line 2625 in
> [0]PETSC ERROR: TSSolve() line 2741 in
> [0]PETSC ERROR: main() line 83 in
> /home/mc/PhD/opencl_tests/petsc_opencl/petsc_opencl.cpp
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode -473550369.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> The error occured at VecViennaCLGetArrayRead/Write in my
> ComputeResidualViennaCL function. Note that with the petsc debug mode,
> the code crashes with the above error even if I don't catch the error
> codes. Might be because of some VecViennaCLGetArray calls inside petsc.
> Cheers,
> Mani
> On Sat, Jan 25, 2014 at 2:48 AM, Karl Rupp <rupp at mcs.anl.gov
> <mailto:rupp at mcs.anl.gov>> wrote:
> Hi Mani,
> please check the return value of *all* function calls from PETSc, e.g.
> ierr = DMCreateGlobalVector(da, &soln);CHKERRQ(ierr);
> instead of just
> Most likely one of the routines threw an error, but your code just
> kept going, producing wrong results.
> Best regards,
> Karli
> On 01/25/2014 05:35 AM, Mani Chandra wrote:
> Hi Everyone,
> I'm trying to use TS with ViennaCL vecs/mats and residual
> evaluation on
> device and have encountered some problems. I have attached a
> small test
> code that illustrates the issue.
> The code simply advects a blob diagonally using TS. I have
> written the
> residual evaluation function using 1) the usual Petsc vectors
> (VecGetArray) and 2) using ViennaCL vectors
> (VecViennaCLGetArrayRead/__Write).
> Run the code using the following:
> ./petsc_opencl -ts_monitor -snes_monitor -ts_max_steps 1000 -ts_type
> theta -ts_dt 10 -snes_rtol 1e-4 -ts_final_time 1000
> -ts_monitor_draw_solution
> Case 1) No ViennaCL anywhere. I simply use the usual Petsc
> vectors and
> set the residual evaluation function as ComputeResidual (line
> no. 55).
> This case works and the blob is indeed advected as can be seen. (I
> haven't bothered with the boundaries. The simulation just stops
> before
> the blob hits the boundaries).
> Case 2) We again use the ComputeResidual but now enable ViennaCL
> vecs
> and mats (line nos. 48, 49). This case does NOT work. The SNES
> monitor
> shows convergence but the solution makes no sense.
> Case 3) We now use ComputeResidualViennaCL (line no. 56). This
> does NOT
> work either with or without enabling the ViennaCL vecs (line
> nos. 48, 49).
> Cheers,
> Mani
