[petsc-dev] Possible bugs when using TS with ViennaCL
Mani Chandra
mc0710 at gmail.com
Sat Jan 25 15:07:52 CST 2014
Hi Karl,
I now checked the error flags of all petsc functions in all functions. I
also recompiled petsc with debug. Here's the report:
Case 1) Still works. All good.
Case 2) This is the case with ComputeResidual using VecGetArrays but with
DMSetVecType(da, VECVIENNACL) and DMSetMatType(da, MATAIJVIENNACL). The
flags don't show any errors. *The programs proceeds smoothly but the
solution is wrong even though SNES is converging.*
Case 3) This is the case with ComputeResidualViennaCL using
VecViennaCLGetArrays with and without DMSetVecType(da, VECVIENNACL) and
DMSetMatType(da, MATAIJVIENNACL). In both cases I get the following error:
[0]PETSC ERROR: TSComputeIFunction() line 676 in
/home/mc/Downloads/petsc/src/ts/interface/ts.c
[0]PETSC ERROR: SNESTSFormFunction_Theta() line 284 in
/home/mc/Downloads/petsc/src/ts/impls/implicit/theta/theta.c
[0]PETSC ERROR: SNESTSFormFunction() line 3499 in
[0]PETSC ERROR: SNESComputeFunction() line 2089 in
/home/mc/Downloads/petsc/src/snes/interface/snes.c
[0]PETSC ERROR: SNESSolve_NEWTONLS() line 175 in
/home/mc/Downloads/petsc/src/snes/impls/ls/ls.c
[0]PETSC ERROR: SNESSolve() line 3812 in
[0]PETSC ERROR: TSStep_Theta() line 183 in
[0]PETSC ERROR: TSStep() line 2625 in
[0]PETSC ERROR: TSSolve() line 2741 in
[0]PETSC ERROR: main() line 83 in
/home/mc/PhD/opencl_tests/petsc_opencl/petsc_opencl.cpp
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode -473550369.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
The error occured at VecViennaCLGetArrayRead/Write in my
ComputeResidualViennaCL function. Note that with the petsc debug mode, the
code crashes with the above error even if I don't catch the error codes.
Might be because of some VecViennaCLGetArray calls inside petsc.
Cheers,
Mani
On Sat, Jan 25, 2014 at 2:48 AM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hi Mani,
> please check the return value of *all* function calls from PETSc, e.g.
> ierr = DMCreateGlobalVector(da, &soln);CHKERRQ(ierr);
> instead of just
> Most likely one of the routines threw an error, but your code just kept
> going, producing wrong results.
> Best regards,
> Karli
> On 01/25/2014 05:35 AM, Mani Chandra wrote:
>> Hi Everyone,
>> I'm trying to use TS with ViennaCL vecs/mats and residual evaluation on
>> device and have encountered some problems. I have attached a small test
>> code that illustrates the issue.
>> The code simply advects a blob diagonally using TS. I have written the
>> residual evaluation function using 1) the usual Petsc vectors
>> (VecGetArray) and 2) using ViennaCL vectors (VecViennaCLGetArrayRead/
>> Write).
>> Run the code using the following:
>> ./petsc_opencl -ts_monitor -snes_monitor -ts_max_steps 1000 -ts_type
>> theta -ts_dt 10 -snes_rtol 1e-4 -ts_final_time 1000
>> -ts_monitor_draw_solution
>> Case 1) No ViennaCL anywhere. I simply use the usual Petsc vectors and
>> set the residual evaluation function as ComputeResidual (line no. 55).
>> This case works and the blob is indeed advected as can be seen. (I
>> haven't bothered with the boundaries. The simulation just stops before
>> the blob hits the boundaries).
>> Case 2) We again use the ComputeResidual but now enable ViennaCL vecs
>> and mats (line nos. 48, 49). This case does NOT work. The SNES monitor
>> shows convergence but the solution makes no sense.
>> Case 3) We now use ComputeResidualViennaCL (line no. 56). This does NOT
>> work either with or without enabling the ViennaCL vecs (line nos. 48, 49).
>> Cheers,
>> Mani
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140125/7240042a/attachment.html>
