[petsc-dev] the non-implemented case of PetscFEIntegrateResidual et al.
    Matthew Knepley
    knepley at gmail.com
    Wed Jan 22 14:06:26 CST 2014
On Wed, Jan 22, 2014 at 2:01 PM, Geoffrey Irving <irving at naml.us> wrote:
> If a PetscFE object doesn't define integrateresidual, a call to
> PetscFEIntegrateResidual silently does nothing.  Is this intended
> behavior, or would it be better to complain similar to what happens
> for an undefined matrix operation?  I ask because I'm about to add an
> operation (PetscFEIntegrateScalars) which will initially only be
> defined in basic mode.
You are correct, it should error. THis is left over from me building it.
     Matt
> Geoffrey
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140122/7edb0c0b/attachment.html>
