[petsc-dev] PCBDDC
Jed Brown jed at jedbrown.org
Sun Jan 19 16:58:31 CST 2014
Stefano Zampini <stefano.zampini at gmail.com> writes:
> Hi,
> I think PCBDDC is now stable enough to be available without the
> configure switch --with-pcbddc. Could you please review and merge my
> opened pull requests (134, 135 and 136) and remove the configure
> switch together with the int64 restriction on the PCBDDC package?
I've been traveling continuously since you wrote this, but I'll merge
them soon and enable by default in 'next' to see what the nightlies have
to say.
> I would like to solve any issues coming from the nightly builds before
> the next release. If it is not safe to do this, I'm waiting for
> suggestions.
I see you're not on petsc-maint, but there was a recent support issue;
will Cc you on that.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140119/0573307d/attachment.sig>
