[petsc-dev] --download-numpy should it still exist?
Barry Smith
bsmith at mcs.anl.gov
Wed Aug 27 22:15:14 CDT 2014
It doesn’t work for me. Should it still exist? Does the tar ball just need to be updated?
Error running setup.py on numpy: Could not execute "sudo mkdir -p /Users/barrysmith/Src/petsc/arch-basic/externalpackages/numpy-1.0.4 && cd /Users/barrysmith/Src/petsc/arch-basic/externalpackages/numpy-1.0.4 && sudo python setup.py install --prefix=/Users/joe":
non-existing path in 'numpy/distutils': 'site.cfg'
F2PY Version 2_4422Running from numpy source directory.
Traceback (most recent call last):
File "setup.py", line 89, in <module>
setup_package()
File "setup.py", line 82, in setup_package
configuration=configuration )
File "/Users/barrysmith/Src/petsc/arch-basic/externalpackages/numpy-1.0.4/numpy/distutils/core.py", line 145, in setup
config = configuration()
File "setup.py", line 49, in configuration
config.add_subpackage('numpy')
File "/Users/barrysmith/Src/petsc/arch-basic/externalpackages/numpy-1.0.4/numpy/distutils/misc_util.py", line 834, in add_subpackage
caller_level = 2)
File "/Users/barrysmith/Src/petsc/arch-basic/externalpackages/numpy-1.0.4/numpy/distutils/misc_util.py", line 817, in get_subpackage
caller_level = caller_level + 1)
File "/Users/barrysmith/Src/petsc/arch-basic/externalpackages/numpy-1.0.4/numpy/distutils/misc_util.py", line 764, in _get_configuration_from_setup_py
config = setup_module.configuration(*args)
File "numpy/setup.py", line 9, in configuration
config.add_subpackage('core')
caller_level = 2)
File "numpy/core/setup.py", line 246, in configuration
blas_info = get_info('blas_opt',0)
File "/Users/barrysmith/Src/petsc/arch-basic/externalpackages/numpy-1.0.4/numpy/distutils/system_info.py", line 267, in get_info
return cl().get_info(notfound_action)
File "/Users/barrysmith/Src/petsc/arch-basic/externalpackages/numpy-1.0.4/numpy/distutils/system_info.py", line 366, in __init__
self.parse_config_files()
File "/Users/barrysmith/Src/petsc/arch-basic/externalpackages/numpy-1.0.4/numpy/distutils/system_info.py", line 374, in parse_config_files
self.cp.add_section(self.section)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ConfigParser.py", line 261, in add_section
raise ValueError, 'Invalid section name: %s' % section
ValueError: Invalid section name: DEFAULT
