[petsc-dev] what the hey is FFC
Jed Brown
jed at jedbrown.org
Wed Aug 27 17:22:51 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
> =============================================================================== Trying to download http://www.fenics.org/pub/software/ffc/v0.3/ffc-0.3.3.tar.gz for FFC =============================================================================== *******************************************************************************
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> file could not be opened successfully
> Downloaded package FFC from: http://www.fenics.org/pub/software/ffc/v0.3/ffc-0.3.3.tar.gz is not a tarball.
> [or installed python cannot process compressed files]
> fenics.org doesn’t seem around any more.
It was renamed to fenicsproject.org many years ago.
> And what is the business of having a tar ball but needing no install?
> Surely it must at least need to be put some where?
It is a Python code-generation package. With Sieve gone, I'm pretty sure it can be deleted.
> Can FFC.py be removed?
> class Configure(PETSc.package.NewPackage):
> def __init__(self, framework):
> PETSc.package.NewPackage.__init__(self, framework)
> self.download = ['http://www.fenics.org/pub/software/ffc/v0.3/ffc-0.3.3.tar.gz']
> return
> def setupDependencies(self, framework):
> PETSc.package.NewPackage.setupDependencies(self, framework)
> self.fiat = self.framework.require('config.packages.fiat', self)
> self.deps = [self.fiat]
> return
> def Install(self):
> import sys
> ffcDir = self.getDir()
> # We could make a check of the md5 of the current configure framework
> self.logPrintBox('FFC needs no installation')
> self.framework.actions.addArgument('FFC', 'Install', 'Installed FFC into '+ffcDir)
> return ffcDir
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140827/50fb1794/attachment.sig>
