[petsc-dev] DMPlexCreateSection from fortran
Adrian Croucher a.croucher at auckland.ac.nz
Thu Aug 7 19:01:20 CDT 2014
hi
I'm getting a compile-time error when calling DMPlexCreateSection() from
fortran. The error is:
        num_bc, pbc_field, pbc_pointIS, section, ierr); if (ierr .ne. 0)
call MP
                                                 1
Error: Type mismatch in argument 'section' at (1); passed INTEGER(4) to
INTEGER(8)
The code is below. (I'm not sure if there is a simpler way to do this
that doesn't require all those extra pointer variables.) I based it on
the C code in SNES ex12.
Is my code wrong or could it be a bug? I'm using the 'next' branch of PETSc.
Cheers, Adrian
subroutine setup_dm_section(dm)
   ! Sets up section on dm.
   implicit none
#include <finclude/petsc.h90>
   DM, intent(in out) :: dm
   ! Locals:
   PetscInt, parameter :: dim = 3, num_fields = 1
   PetscInt, target :: num_comp(1) = [1], num_dof(3) = [0,0,1]
   PetscInt, pointer :: pnum_comp(:), pnum_dof(:)
   PetscInt, parameter :: num_bc = 0
   PetscInt, target :: bc_field(1) = [0]
   PetscInt, pointer :: pbc_field(:)
   IS, target :: bc_pointIS(1)
   IS, pointer :: pbc_pointIS(:)
   PetscSection :: section
   PetscErrorCode :: ierr
   pnum_comp => num_comp; pnum_dof => num_dof
   pbc_field => bc_field; pbc_pointIS => bc_pointIS
   call DMPlexCreateSection(dm, dim, num_fields, pnum_comp, pnum_dof, &
        num_bc, pbc_field, pbc_pointIS, section, ierr); CHKERRQ(ierr)
   call PetscSectionSetFieldName(section, 0, "y", ierr); CHKERRQ(ierr)
   call PetscSectionSetUp(section, ierr); CHKERRQ(ierr)
   call DMSetDefaultSection(dm, section); CHKERRQ(ierr)
   call PetscSectionDestroy(section, ierr); CHKERRQ(ierr)
end subroutine setup_dm_section
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
