[petsc-dev] PCComputeExplicitOperator error
Barry Smith
bsmith at mcs.anl.gov
Wed Aug 6 10:42:59 CDT 2014
Fixed in maint, next and master
On Aug 4, 2014, at 1:35 PM, Mark Adams <mfadams at lbl.gov> wrote:
> I am getting a new-non-zero error in PCComputeExplicitOperator at the bottom of precon.c. it looks like the matrix is set to have not memory:
> PetscErrorCode PCComputeExplicitOperator(PC pc,Mat *mat)
> if (size == 1) { ierr = MatSetType(*mat,MATSEQDENSE);CHKERRQ(ierr);
> ierr = MatSeqDenseSetPreallocation(*mat,NULL);CHKERRQ(ierr);
> } else {
> ierr = MatSetType(*mat,MATMPIAIJ);CHKERRQ(ierr);
> ierr = MatMPIAIJSetPreallocation(*mat,0,NULL,0,NULL);CHKERRQ(ierr);
> ierr = MatSetValues(*mat,m,rows,1,&i,array,INSERT_VALUES);CHKERRQ(ierr);
> I get the error on this last line (#1835 precon.c). Matt mentioned that this code needed work. I can work on this but am not sure about the best way to proceed. I am doing a full Schur complement and don't mind simply going through and solving for each column of A_01 in A_00^-1 * A_01. I guess the pc->pmat is a matrix shell with (A_11 - A_10 * A_00^-1 * A_01).
> should this just be a dense matrix in parallel as well as not?
> Mark
