[petsc-dev] PCComputeExplicitOperator error
Mark Adams
mfadams at lbl.gov
Mon Aug 4 13:35:57 CDT 2014
I am getting a new-non-zero error in PCComputeExplicitOperator at the
bottom of precon.c. it looks like the matrix is set to have not memory:
PetscErrorCode PCComputeExplicitOperator(PC pc,Mat *mat)
if (size == 1) { ierr = MatSetType(*mat,MATSEQDENSE);CHKERRQ(ierr);
ierr = MatSeqDenseSetPreallocation(*mat,NULL);CHKERRQ(ierr);
} else {
ierr = MatSetType(*mat,MATMPIAIJ);CHKERRQ(ierr);
ierr = MatMPIAIJSetPreallocation(*mat,0,NULL,0,NULL);CHKERRQ(ierr);
ierr = MatSetValues(*mat,m,rows,1,&i,array,INSERT_VALUES);CHKERRQ(ierr);
I get the error on this last line (#1835 precon.c). Matt mentioned that
this code needed work. I can work on this but am not sure about the best
way to proceed. I am doing a full Schur complement and don't mind simply
going through and solving for each column of A_01 in A_00^-1 * A_01. I
guess the pc->pmat is a matrix shell with (A_11 - A_10 * A_00^-1 * A_01).
should this just be a dense matrix in parallel as well as not?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140804/bed1fe25/attachment.html>
