[petsc-dev] petsc-dev installation error on Edison
Gautam Bisht
gbisht at lbl.gov
Fri Aug 1 16:06:25 CDT 2014
I'm getting an error while trying to install petsc-dev on Edison with GUN
compilers. Attached below is configure.log and additional command line
outputs.
> module list -t
Currently Loaded Modulefiles:
modules/3.2.6.7
nsg/1.2.0
eswrap/1.1.0-1.020200.1130.0
switch/1.0-1.0502.51632.2.84.ari
craype-network-aries
craype/2.1.2
craype-ivybridge
cray-shmem/7.0.0
cray-mpich/7.0.0
torque/4.2.7
moab/7.2.7-e7c070d1-b3-SUSE11
altd/1.0
darshan/2.3.0
usg-default-modules/1.1
gcc/4.9.0
cray-libsci/13.0.0
udreg/2.3.2-1.0502.8763.1.11.ari
ugni/5.0-1.0502.9037.7.26.ari
pmi/5.0.4-1.0000.10161.132.4.ari
dmapp/7.0.1-1.0502.9080.9.32.ari
gni-headers/3.0-1.0502.9038.7.4.ari
xpmem/0.1-2.0502.51169.1.11.ari
job/1.5.5-0.1_2.0502.52111.3.39.ari
csa/3.0.0-1_2.0502.51200.1.108.ari
alps/5.2.1-2.0502.8712.10.32.ari
rca/1.0.0-2.0502.51491.3.92.ari
atp/1.7.3
PrgEnv-gnu/5.2.25
cmake/2.8.11.2
cray-hdf5-parallel/1.8.13
mercurial/2.7.1
>git clone https://bitbucket.org/petsc/petsc petsc.0c8c14c5
cd petsc.0c8c14c5
git checkout 0c8c14c5
>cat config/configure-edison-gnu-4.9.0-debug.py
#!/usr/bin/env python
if __name__ == '__main__':
import sys
import os
sys.path.insert(0, os.path.abspath('config'))
import configure
configure_options = [
'--with-cc=cc',
'--with-cxx=CC',
'--with-fc=ftn',
'--with-ld=cc',
'--with-cpp=cpp',
'--with-shared-libraries=0',
'--with-gnu-compilers=0',
'--with-debugging=0',
'--with-clanguage=c',
'--with-x=0',
'--with-clib-autodetect=0',
'--with-fortranlib-autodetect=0',
'--with-cxxlib-autodetect=0',
'--COPTFLAGS="-O3 -msse3 -fPIC"',
'--FOPTFLAGS="-O3 -msse3 -fPIC"',
'--download-parmetis=1',
'--download-metis=1',
'--with-hdf5=1',
'--with-hdf5-dir=/opt/cray/hdf5-parallel/1.8.13/GNU/49',
'--with-mpi-dir=/opt/cray/mpt/7.0.0/gni/mpich2-gnu/49',
'--with-c2html=0',
'--PETSC_ARCH=edison-gnu-4.9.0-debug',
configure.petsc_configure(configure_options)
Any ideas what is wrong?
Thanks
-Gautam.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140801/38814514/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140801/38814514/attachment.obj>
