[petsc-dev] triangle error?
Satish Balay
balay at mcs.anl.gov
Thu Sep 26 11:30:17 CDT 2013
On Thu, 26 Sep 2013, Satish Balay wrote:
> On Thu, 26 Sep 2013, Matthew Knepley wrote:
> > On Thu, Sep 26, 2013 at 9:02 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > balay at asterix /home/balay/petsc.clone (master)
> > > $ git branch -r --contains 2fa0603007e1e64b1eaf7257d86de9c8fbebfd01
> > > origin/HEAD -> origin/master
> > > origin/knepley/fix-plex-regression
> > > origin/knepley/fix-triangle-make
> > > origin/master
> > > This fix should have gone into jed/gnumake.
> > That had already gone to master, so I made another branch and fixed master.
> Usually the fixes still go into the branch [where the issue came from]
> and remerge this branch into master.
> perhaps its not a big deal to keep the branch consistant. [in which
> case we should purge such branches]
ok - made a duplicdate fix in jed/gmake [this would be an automerge anyway] - and merged
to master/next with other fixes.
Satih
> Satish
> > Thanks,
> > Matt
> > > Whats the recommended way to do this now? cherrypick - or merge
> > > origin/knepley/fix-triangle-make?
> > > [what about origin/knepley/fix-plex-regression?]
> > > $ git grep make\\.flags
> > > config/PETSc/packages/tetgen.py: g.write('OMAKE =
> > > '+self.make.make+' '+self.make.flags+'\n')
> > > tetgen also needs this fix.
> > > Satish
> > > AlsoOn Thu, 26 Sep 2013, Satish Balay wrote:
> > > > I see Matt pushed a fix for this.
> > > > Satish
> > > > On Thu, 26 Sep 2013, Mark F. Adams wrote:
> > > > > I thought I got my machine working last week but now I seem to get a
> > > Triangle error. I did nuke everything before I ran this.
> > > > > Mark
