[petsc-dev] triangle error?
Thu Sep 26 11:22:40 CDT 2013
On Thu, 26 Sep 2013, Matthew Knepley wrote:
> On Thu, Sep 26, 2013 at 9:02 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > balay at asterix /home/balay/petsc.clone (master)
> > $ git branch -r  --contains 2fa0603007e1e64b1eaf7257d86de9c8fbebfd01
> >   origin/HEAD -> origin/master
> >   origin/knepley/fix-plex-regression
> >   origin/knepley/fix-triangle-make
> >   origin/master
> > This fix should have gone into jed/gnumake.
> That had already gone to master, so I made another branch and fixed master.
Usually the fixes still go into the branch [where the issue came from]
and remerge this branch into master.
perhaps its not a big deal to keep the branch consistant. [in which
case we should purge such branches]
Satish
>   Thanks,
>      Matt
> > Whats the recommended way to do this now? cherrypick - or merge
> > origin/knepley/fix-triangle-make?
> > [what about origin/knepley/fix-plex-regression?]
> > $ git grep make\\.flags
> > config/PETSc/packages/tetgen.py:    g.write('OMAKE            =
> > '+self.make.make+' '+self.make.flags+'\n')
> > tetgen also needs this fix.
> > Satish
> > AlsoOn Thu, 26 Sep 2013, Satish Balay wrote:
> > > I see Matt pushed a fix for this.
> > > Satish
> > > On Thu, 26 Sep 2013, Mark F. Adams wrote:
> > > > I thought I got my machine working last week but now I seem to get a
> > Triangle error.  I did nuke everything before I ran this.
> > > > Mark
