[petsc-dev] candidate branches for maint
Satish Balay
balay at mcs.anl.gov
Wed Sep 25 16:07:58 CDT 2013
On Wed, 25 Sep 2013, Matthew Knepley wrote:
> On Wed, Sep 25, 2013 at 12:50 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > balay at asterix /home/balay/petsc.clone (next)
> > $ candidate-branches master maint
> > Candidate for maint: refs/remotes/origin/jed/attribute-deprecated-compat
> > Sun Sep 1 18:35:59 2013 -0700
> > <the following to be skipped per previous discussion?>
> > Candidate for maint: refs/remotes/origin/jed/pcmg-residual-underscore Wed
> > Jun 26 16:22:39 2013 -0500
> > Candidate for maint: refs/remotes/origin/karlrupp/feature-viennacl Mon Jun
> > 10 16:44:57 2013 -0500
> > Candidate for maint: refs/remotes/origin/knepley/fix-configure-package Wed
> > Jul 17 07:53:11 2013 -0500
> > Candidate for maint: refs/remotes/origin/knepley/fix-mat-chop Wed May 29
> > 06:46:26 2013 -0500
> > Candidate for maint: refs/remotes/origin/knepley/fix-plex-orient Thu May
> > 16 17:32:38 2013 -0500
> > Candidate for maint: refs/remotes/origin/knepley/remove-sieve Mon May 13
> > 21:54:24 2013 -0500
> > Candidate for maint: refs/remotes/origin/knepley/reordering Tue Aug 27
> > 22:39:10 2013 -0500
> > Candidate for maint: refs/remotes/origin/prbrune/pcgamg-classical Thu Jun
> > 27 12:30:19 2013 -0500
> > Candidate for maint: refs/remotes/origin/prbrune/snes-npcjacobianlagging
> > Tue May 14 09:50:15 2013 -0500
> I pushed all those to 'master' already I thought. I was done with them.
I'm looking for branches that should go into 'maint' branch [and
subsequently the updated petsc-3.4 tarball]. So if these branches are
destined to master - and are already in master - then thats fine. [i.e
they are not destined to go into 'maint' so will not be merged to
maint - as metioned above]
The script isn't perfect [as its listing such braches that started off
3.4 or prior master (aka belongs to current 'maint') - but destined to
current master only].
Satish
> Matt
> > $ candidate-branches next maint
> > refs/remotes/origin/balay/fix-fenv.h-check-on-cygwin64 Wed Sep 25 13:53:25
> > 2013 -0500
> > Candidate for maint: refs/remotes/origin/barry/fix-dgmres.c Mon Sep 16
> > 16:38:15 2013 -0700
> > Candidate for maint: refs/remotes/origin/barry/hyprewithprinterrors Sat
> > Aug 24 09:25:39 2013 -0500
> > Candidate for maint: refs/remotes/origin/prbrune/snes-jacobiancolormgfix
> > Thu Aug 29 14:18:01 2013 -0500
> > 22:39:10 2013 -0500
> > <the following should be skipped?>
> > Candidate for maint: refs/remotes/origin/jed/ksp-cheby-axpbypcz Fri Jun 28
> > 11:23:57 2013 -0500
> > Candidate for maint: refs/remotes/origin/knepley/dm-view-partition Wed May
> > 22 14:32:54 2013 -0400
> > Candidate for maint: refs/remotes/origin/knepley/fix-builder-package-check
> > Thu May 30 21:00:46 2013 -0400
> > 21:54:24 2013 -0500
> > Candidate for maint: refs/remotes/origin/shri/ts-dae-semi-explicit Wed May
> > 8 15:46:56 2013 -0500
> > refs/remotes/origin/stefano_zampini/pcbddc-orthonormalroutine Fri Jul 12
> > 14:56:05 2013 +0200
> > BTW: what about: jed/avoid-getpwuid ? [the above script is not catching
> > it..]
> > Satish
