[petsc-dev] candidate branches for maint
Wed Sep 25 16:00:45 CDT 2013
On Wed, Sep 25, 2013 at 12:50 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> balay at asterix /home/balay/petsc.clone (next)
> $ candidate-branches master maint
> Candidate for maint: refs/remotes/origin/jed/attribute-deprecated-compat
> Sun Sep 1 18:35:59 2013 -0700
> <the following to be skipped per previous discussion?>
> Candidate for maint: refs/remotes/origin/jed/pcmg-residual-underscore Wed
> Jun 26 16:22:39 2013 -0500
> Candidate for maint: refs/remotes/origin/karlrupp/feature-viennacl Mon Jun
> 10 16:44:57 2013 -0500
> Candidate for maint: refs/remotes/origin/knepley/fix-configure-package Wed
> Jul 17 07:53:11 2013 -0500
> Candidate for maint: refs/remotes/origin/knepley/fix-mat-chop Wed May 29
> 06:46:26 2013 -0500
> Candidate for maint: refs/remotes/origin/knepley/fix-plex-orient Thu May
> 16 17:32:38 2013 -0500
> Candidate for maint: refs/remotes/origin/knepley/remove-sieve Mon May 13
> 21:54:24 2013 -0500
> Candidate for maint: refs/remotes/origin/knepley/reordering Tue Aug 27
> 22:39:10 2013 -0500
> Candidate for maint: refs/remotes/origin/prbrune/pcgamg-classical Thu Jun
> 27 12:30:19 2013 -0500
> Candidate for maint: refs/remotes/origin/prbrune/snes-npcjacobianlagging
> Tue May 14 09:50:15 2013 -0500
I pushed all those to 'master' already I thought. I was done with them.
   Matt
> $ candidate-branches next maint
> refs/remotes/origin/balay/fix-fenv.h-check-on-cygwin64 Wed Sep 25 13:53:25
> 2013 -0500
> Candidate for maint: refs/remotes/origin/barry/fix-dgmres.c Mon Sep 16
> 16:38:15 2013 -0700
> Candidate for maint: refs/remotes/origin/barry/hyprewithprinterrors Sat
> Aug 24 09:25:39 2013 -0500
> Candidate for maint: refs/remotes/origin/prbrune/snes-jacobiancolormgfix
> Thu Aug 29 14:18:01 2013 -0500
> 22:39:10 2013 -0500
> <the following should be skipped?>
> Candidate for maint: refs/remotes/origin/jed/ksp-cheby-axpbypcz Fri Jun 28
> 11:23:57 2013 -0500
> Candidate for maint: refs/remotes/origin/knepley/dm-view-partition Wed May
> 22 14:32:54 2013 -0400
> Candidate for maint: refs/remotes/origin/knepley/fix-builder-package-check
> Thu May 30 21:00:46 2013 -0400
> 21:54:24 2013 -0500
> Candidate for maint: refs/remotes/origin/shri/ts-dae-semi-explicit Wed May
> 8 15:46:56 2013 -0500
> refs/remotes/origin/stefano_zampini/pcbddc-orthonormalroutine Fri Jul 12
> 14:56:05 2013 +0200
> BTW: what about: jed/avoid-getpwuid ? [the above script is not catching
> it..]
> Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130925/3c1430f1/attachment.html>
