[petsc-dev] MATMPIAIJ
Jose David Bermeol
jbermeol at purdue.edu
Tue Sep 24 11:07:07 CDT 2013
Hi, I have some questions?
1) What is the main reason to split the matrix in each MPI process in diagonal matrix and off diagonal matrix?
2) Is this just for MATMPIAIJ matrices?
3) Right now we are interested in safe all the memory as possible, so I guess the right path would be to implement a new type of matrix it would be just a container. Is it the best solution??
