[petsc-dev] Explicitly check for InfOrNan fnorm in SNESSolve_XXX?
Dmitry Karpeyev
karpeev at mcs.anl.gov
Mon Sep 23 16:38:10 CDT 2013
Should SNESSolve_NEWTONLS and friends explicitly run the
PetscIsInfOrNanReal check on fnorm before feeding it into
snes->ops->converged? We do make this explicit check on the initial norm
after all. Alternatively, should even the initial norm be checked using
Currently we let the user decide how to deal with an InfOrNan norm after a
SNES iteration, but force a return with SNES_DIVERGED_FNORM_NAN if the
initial norm is crazy. This is a minor issue, especially since it's hard
to imagine how any reasonable convergence test might return anything other
than SNES_DIVERGED_FNORM_NAN in this case, but it is a potential
inconsistency.
Dmitry.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130923/f45b0463/attachment.html>
