[petsc-dev] Error in PetscMallocValidate
Mon Sep 23 17:47:37 CDT 2013
On Mon, Sep 23, 2013 at 1:14 PM, John Mousel <john.mousel at gmail.com> wrote:
> I just pulled from petsc-dev and I'm now getting the following error. The
> result from valgrind is pasted below the error message.
> Any help would be appreciated.
Looks like BLAS errors, but valgrind has a problem with StateIncrease().
Jed just changed the size of the
state counter. Are you sure everything rebuilt correctly?
  Matt
> John
> [0]PETSC ERROR: PetscMallocValidate: error detected at MatScale_SeqAIJ()
> line 2464 in src/mat/impls/aij/seq/aij.c
> [0]PETSC ERROR: [1]PETSC ERROR: [2]PETSC ERROR: Memory [id=0(48)] at
> address 0x8483450 is corrupted (probably write past end of array)
> [0]PETSC ERROR: Memory originally allocated in
> PetscObjectComposedDataIncreaseReal() line 171 in src/sys/objects/state.c
> PetscMallocValidate: error detected at MatScale_SeqAIJ() line 2464 in
> [2]PETSC ERROR: [1]PETSC ERROR: [0]PETSC ERROR: ---------------------
> Error Message ------------------------------------
> [0]PETSC ERROR: Memory corruption!
> [0]PETSC ERROR:  !
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Development GIT revision:
> b4e904d1358c92c43842a940440f995d2117e40b  GIT Date: 2013-09-23 12:36:08
> +0100
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ../src/CYLINDER_EXE on a gnu-debug named wv.iihr.uiowa.eduby jmousel Mon Sep 23 15:07:15 2013
> [0]PETSC ERROR: Libraries linked from
> /home/jmousel/NumericalLibraries/petsc/gnu-debug/lib
> [0]PETSC ERROR: Configure run at Mon Sep 23 15:04:14 2013
> [0]PETSC ERROR: Configure options --download-cmake=1
> --download-f-blas-lapack=1 --download-metis=1 --download-mpich=1
> --download-parmetis=1 --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
> PETSC_ARCH=gnu-debug
> [0]PETSC ERROR:
> [0]PETSC ERROR: PetscMallocValidate() line 149 in src/sys/memory/mtr.c
> [0]PETSC ERROR: MatScale_SeqAIJ() line 2464 in src/mat/impls/aij/seq/aij.c
> [0]PETSC ERROR: MatScale() line 4758 in src/mat/interface/matrix.c
> [0]PETSC ERROR: MatScale_MPIAIJ() line 1262 in
> src/mat/impls/aij/mpi/mpiaij.c
> [0]PETSC ERROR: MatAYPX() line 279 in src/mat/utils/axpy.c
> [0]PETSC ERROR: PCGAMGOptprol_AGG() line 1331 in
> src/ksp/pc/impls/gamg/agg.c
> [0]PETSC ERROR: PCSetUp_GAMG() line 597 in src/ksp/pc/impls/gamg/gamg.c
> [0]PETSC ERROR: PCSetUp() line 890 in src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: KSPSolve() line 399 in src/ksp/ksp/interface/itfunc.c
> Memory [id=0(48)] at address 0x8556ca0 is corrupted (probably write past
> end of array)
> [1]PETSC ERROR: Memory originally allocated in
> [1]PETSC ERROR: Memory [id=0(48)] at address 0x9308690 is corrupted
> --------------------- Error Message ------------------------------------
> [2]PETSC ERROR: Memory originally allocated in
> [1]PETSC ERROR: Memory corruption!
> [1]PETSC ERROR:  !
> [1]PETSC ERROR:
> [1]PETSC ERROR: Petsc Development GIT revision:
> +0100
> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
> [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [1]PETSC ERROR: See docs/index.html for manual pages.
> [1]PETSC ERROR:
> [1]PETSC ERROR: ../src/CYLINDER_EXE on a gnu-debug named wv.iihr.uiowa.eduby jmousel Mon Sep 23 15:07:15 2013
> [1]PETSC ERROR: Libraries linked from
> [1]PETSC ERROR: Configure run at Mon Sep 23 15:04:14 2013
> [1]PETSC ERROR: Configure options --download-cmake=1
> [1]PETSC ERROR:
> [1]PETSC ERROR: PetscMallocValidate() line 149 in src/sys/memory/mtr.c
> [2]PETSC ERROR: --------------------- Error Message
> [2]PETSC ERROR: Memory corruption!
> [2]PETSC ERROR:  !
> [2]PETSC ERROR:
> [2]PETSC ERROR: Petsc Development GIT revision:
> +0100
> [2]PETSC ERROR: See docs/changes/index.html for recent updates.
> [2]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [2]PETSC ERROR: See docs/index.html for manual pages.
> [1]PETSC ERROR: [2]PETSC ERROR: MatScale_SeqAIJ() line 2464 in
> [2]PETSC ERROR: ../src/CYLINDER_EXE on a gnu-debug named wv.iihr.uiowa.eduby jmousel Mon Sep 23 15:07:15 2013
> [1]PETSC ERROR: [2]PETSC ERROR: MatScale() line 4758 in
> Libraries linked from /home/jmousel/NumericalLibraries/petsc/gnu-debug/lib
> [2]PETSC ERROR: Configure run at Mon Sep 23 15:04:14 2013
> [1]PETSC ERROR: [2]PETSC ERROR: Configure options --download-cmake=1
> MatScale_MPIAIJ() line 1262 in src/mat/impls/aij/mpi/mpiaij.c
> [2]PETSC ERROR:
> [1]PETSC ERROR: MatScale() line 4758 in src/mat/interface/matrix.c
> [2]PETSC ERROR: PetscMallocValidate() line 149 in src/sys/memory/mtr.c
> [1]PETSC ERROR: MatAYPX() line 279 in src/mat/utils/axpy.c
> [1]PETSC ERROR: PCGAMGOptprol_AGG() line 1331 in
> [1]PETSC ERROR: PCSetUp_GAMG() line 597 in src/ksp/pc/impls/gamg/gamg.c
> [1]PETSC ERROR: PCSetUp() line 890 in src/ksp/pc/interface/precon.c
> [1]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
> [1]PETSC ERROR: KSPSolve() line 399 in src/ksp/ksp/interface/itfunc.c
> [2]PETSC ERROR: MatScale_SeqAIJ() line 2464 in src/mat/impls/aij/seq/aij.c
> [2]PETSC ERROR: MatScale() line 4758 in src/mat/interface/matrix.c
> [2]PETSC ERROR: MatScale_MPIAIJ() line 1262 in
> [2]PETSC ERROR: MatAYPX() line 279 in src/mat/utils/axpy.c
> [2]PETSC ERROR: PCGAMGOptprol_AGG() line 1331 in
> [2]PETSC ERROR: PCSetUp_GAMG() line 597 in src/ksp/pc/impls/gamg/gamg.c
> [2]PETSC ERROR: PCSetUp() line 890 in src/ksp/pc/interface/precon.c
> [2]PETSC ERROR: KSPSetUp() line 278 in src/ksp/ksp/interface/itfunc.c
> [2]PETSC ERROR: KSPSolve() line 399 in src/ksp/ksp/interface/itfunc.c
> ***[0]PCReset_GAMG this should not happen, cleaned up in SetUp
> [0]PETSC ERROR: PetscTrFreeDefault() called from
> PetscComposedQuantitiesDestroy() line 40 in src/sys/objects/destroy.c
> [0]PETSC ERROR: Block [id=0(48)] at address 0x8482c00 is corrupted
> [0]PETSC ERROR: Block allocated in PetscObjectComposedDataIncreaseReal()
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Corrupted memory!
> [0]PETSC ERROR:
> +0100
> [0]PETSC ERROR:
> [0]PETSC ERROR:
> [0]PETSC ERROR: PetscTrFreeDefault() line 303 in src/sys/memory/mtr.c
> [0]PETSC ERROR: PetscComposedQuantitiesDestroy() line 40 in
> [1]PETSC ERROR: PetscTrFreeDefault() called from
> [1]PETSC ERROR: Block [id=0(48)] at address 0x8556450 is corrupted
> [1]PETSC ERROR: Block allocated in PetscObjectComposedDataIncreaseReal()
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Corrupted memory!
> [1]PETSC ERROR:
> +0100
> [1]PETSC ERROR:
> [1]PETSC ERROR:
> [1]PETSC ERROR: PetscTrFreeDefault() line 303 in src/sys/memory/mtr.c
> [1]PETSC ERROR: PetscComposedQuantitiesDestroy() line 40 in
> [2]PETSC ERROR: PetscTrFreeDefault() called from
> [2]PETSC ERROR: Block [id=0(48)] at address 0x9307e40 is corrupted
> [2]PETSC ERROR: Block allocated in PetscObjectComposedDataIncreaseReal()
> [2]PETSC ERROR: Corrupted memory!
> [2]PETSC ERROR:
> +0100
> [2]PETSC ERROR:
> [2]PETSC ERROR: Libraries linked from
> [2]PETSC ERROR:
> [2]PETSC ERROR: PetscTrFreeDefault() line 303 in src/sys/memory/mtr.c
> [2]PETSC ERROR: PetscComposedQuantitiesDestroy() line 40 in
> [2]PETSC ERROR: PetscMallocValidate: error detected at formProl0() line
> 843 in src/ksp/pc/impls/gamg/agg.c
> [2]PETSC ERROR: Memory [id=0(48)] at address 0x9308690 is corrupted
> [2]PETSC ERROR:  !
> [2]PETSC ERROR:
> +0100
> [2]PETSC ERROR:
> [2]PETSC ERROR:
> [2]PETSC ERROR: formProl0() line 843 in src/ksp/pc/impls/gamg/agg.c
> [2]PETSC ERROR: PCGAMGProlongator_AGG() line 1196 in
> [2]PETSC ERROR: PCSetUp_GAMG() line 588 in src/ksp/pc/impls/gamg/gamg.c
> [1]PETSC ERROR: PetscMallocValidate: error detected at formProl0() line
> [1]PETSC ERROR: Memory [id=0(48)] at address 0x8556ca0 is corrupted
> [1]PETSC ERROR:  !
> [1]PETSC ERROR:
> +0100
> [1]PETSC ERROR:
> [1]PETSC ERROR:
> [1]PETSC ERROR: formProl0() line 843 in src/ksp/pc/impls/gamg/agg.c
> [1]PETSC ERROR: PCGAMGProlongator_AGG() line 1196 in
> [1]PETSC ERROR: PCSetUp_GAMG() line 588 in src/ksp/pc/impls/gamg/gamg.c
> [0]PETSC ERROR: PetscMallocValidate: error detected at formProl0() line
> [0]PETSC ERROR: Memory [id=0(48)] at address 0x8483450 is corrupted
> [0]PETSC ERROR:  !
> [0]PETSC ERROR:
> +0100
> [0]PETSC ERROR:
> [0]PETSC ERROR:
> [0]PETSC ERROR: formProl0() line 843 in src/ksp/pc/impls/gamg/agg.c
> [0]PETSC ERROR: PCGAMGProlongator_AGG() line 1196 in
> [0]PETSC ERROR: PCSetUp_GAMG() line 588 in src/ksp/pc/impls/gamg/gamg.c
> [2]PETSC ERROR: [1]PETSC ERROR: PetscMallocValidate: error detected at
> Memory [id=0(48)] at address 0x9308690 is corrupted (probably write past
> end of array)
> [1]PETSC ERROR: [2]PETSC ERROR: Memory originally allocated in
> end of array)
> [2]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
> Memory originally allocated in PetscObjectComposedDataIncreaseReal() line
> [2]PETSC ERROR:  !
> [2]PETSC ERROR:
> [2]PETSC ERROR: [1]PETSC ERROR: Petsc Development GIT revision:
> +0100
> [2]PETSC ERROR: [1]PETSC ERROR: See docs/index.html for manual pages.
> [2]PETSC ERROR: [1]PETSC ERROR:  !
> [1]PETSC ERROR:
> +0100
> [2]PETSC ERROR:
> ../src/CYLINDER_EXE on a gnu-debug named wv.iihr.uiowa.edu by jmousel Mon
> [2]PETSC ERROR:
> [1]PETSC ERROR: [2]PETSC ERROR: PetscMallocValidate() line 149 in
> PCGAMGProlongator_AGG() line 1196 in src/ksp/pc/impls/gamg/agg.c
> [1]PETSC ERROR: [2]PETSC ERROR: PCSetUp_GAMG() line 588 in
> [1]PETSC ERROR: [2]PETSC ERROR: KSPSolve() line 399 in
> [0]PETSC ERROR:  !
> [0]PETSC ERROR:
> +0100
> [0]PETSC ERROR:
> [0]PETSC ERROR:
> [2]PETSC ERROR: [0]PETSC ERROR: PetscMallocValidate: error detected at
> PetscMallocValidate: error detected at formProl0() line 843 in
> [0]PETSC ERROR: [2]PETSC ERROR: --------------------- Error Message
> end of array)
> [2]PETSC ERROR: [0]PETSC ERROR: Memory originally allocated in
> Memory corruption!
> [0]PETSC ERROR: [2]PETSC ERROR: Memory corruption!
> [2]PETSC ERROR:  !
> [2]PETSC ERROR:  !
> [2]PETSC ERROR: [0]PETSC ERROR: Petsc Development GIT revision:
> +0100
> +0100
> [0]PETSC ERROR:
> [0]PETSC ERROR:
> [2]PETSC ERROR:
> [2]PETSC ERROR:
> [1]PETSC ERROR:  !
> [1]PETSC ERROR:
> +0100
> [1]PETSC ERROR:
> [2]PETSC ERROR: [1]PETSC ERROR: KSPSolve() line 399 in
> Configure options --download-cmake=1 --download-f-blas-lapack=1
> --download-metis=1 --download-mpich=1 --download-parmetis=1 --with-cc=gcc
> --with-cxx=g++ --with-fc=gfortran PETSC_ARCH=gnu-debug
> [1]PETSC ERROR:
> [1]PETSC ERROR: PetscMallocValidate: error detected at VecAXPY_Seq() line
> 257 in src/vec/vec/impls/seq/bvec1.c
> [1]PETSC ERROR:  !
> [1]PETSC ERROR:
> +0100
> [0]PETSC ERROR: [1]PETSC ERROR: PetscMallocValidate: error detected at
> VecAXPY_Seq() line 257 in src/vec/vec/impls/seq/bvec1.c
> [0]PETSC ERROR:  !
> [0]PETSC ERROR:
> +0100
> [1]PETSC ERROR:
> [1]PETSC ERROR:
> [1]PETSC ERROR: VecAXPY_Seq() line 257 in src/vec/vec/impls/seq/bvec1.c
> [0]PETSC ERROR:
> [1]PETSC ERROR: [0]PETSC ERROR: VecAXPY() line 624 in
> src/vec/vec/interface/rvector.c
> [0]PETSC ERROR:
> [0]PETSC ERROR: VecAXPY_Seq() line 257 in src/vec/vec/impls/seq/bvec1.c
> [0]PETSC ERROR: VecAXPY() line 624 in src/vec/vec/interface/rvector.c
> [2]PETSC ERROR: PetscMallocValidate: error detected at VecAXPY_Seq() line
> [2]PETSC ERROR:  !
> [2]PETSC ERROR:
> +0100
> [2]PETSC ERROR:
> [2]PETSC ERROR:
> [2]PETSC ERROR: VecAXPY_Seq() line 257 in src/vec/vec/impls/seq/bvec1.c
> [2]PETSC ERROR: VecAXPY() line 624 in src/vec/vec/interface/rvector.c
> WARNING! There are options you set that were not used!
> WARNING! could be spelling mistake, etc!
> Option left: name:-pres_ksp_type value: preonly
> Option left: name:-pres_pc_type value: redistribute
> Option left: name:-pres_redistribute_ksp_monitor_true_residual (no value)
> Option left: name:-pres_redistribute_ksp_type value: bcgsl
> Option left: name:-pres_redistribute_mg_coarse_ksp_type value: richardson
> Option left: name:-pres_redistribute_mg_coarse_pc_sor_its value: 5
> Option left: name:-pres_redistribute_mg_coarse_pc_type value: sor
> Option left: name:-pres_redistribute_mg_levels_ksp_type value: richardson
> Option left: name:-pres_redistribute_mg_levels_pc_type value: sor
> Option left: name:-pres_redistribute_pc_gamg_agg_nsmooths value: 1
> Option left: name:-pres_redistribute_pc_gamg_sym_graph value: true
> Option left: name:-pres_redistribute_pc_gamg_threshold value: 0.05
> Option left: name:-pres_redistribute_pc_gamg_type value: agg
> Option left: name:-pres_redistribute_pc_type value: gamg
> #-@/home/jmousel/NumericalLibraries/petsc/gnu-debug/bin/mpiexec -n 3
> ../src/CYLINDER_EXE -ELAFINT_case_name cylinder -lspaint_ksp_type bcgsl
> -lspaint_pc_type gamg -lspaint_pc_gamg_type agg
> -lspaint_pc_gamg_agg_nsmooths 1 -lspaint_pc_gamg_sym_graph true
> -lspaint_ksp_monitor -pres_ksp_type bcgsl -pres_pc_type gamg
> -pres_pc_gamg_threshold 0.025 -pres_mg_levels_ksp_type richardson
> -pres_mg_levels_pc_type sor -pres_mg_coarse_ksp_type richardson
> -pres_mg_coarse_pc_type sor -pres_mg_coarse_pc_sor_its 5 -pres_pc_gamg_type
> agg -pres_pc_gamg_agg_nsmooths 2 -pres_pc_gamg_sym_graph true
> -pres_ksp_monitor_true_residual
> ==11740== Invalid write of size 8
> ==11740==    at 0x5830EF0: PCGAMGOptprol_AGG (agg.c:1320)
> ==11740==    by 0x5818ED9: PCSetUp_GAMG (gamg.c:597)
> ==11740==    by 0x5742B21: PCSetUp (precon.c:890)
> ==11740==    by 0x589BEDE: KSPSetUp (itfunc.c:278)
> ==11740==    by 0x589D05C: KSPSolve (itfunc.c:399)
> ==11740==    by 0x58D8CD1: kspsolve_ (itfuncf.c:219)
> ==11740==    by 0x5697F3: axbsolve_ (Axb.F90:141)
> ==11740==    by 0x56F768: lspaintcptflag_ (LevelsetPaint.F90:177)
> ==11740==    by 0x4B72C3: lsinitialize_ (LevelsetInputsInitialize.F90:579)
> ==11740==    by 0x45BF2D: elafintinitialize_ (ElafintInitialize.F90:48)
> ==11740==    by 0x45A260: MAIN__ (ELAFINTMain.F90:43)
> ==11740==    by 0x5A8AC9: main (in
> /home/jmousel/Desktop/RobinsBCs/src/CYLINDER_EXE)
> ==11740==  Address 0x8556cd0 is 2,176 bytes inside a block of size 2,180
> alloc'd
> ==11740==    at 0x4A05548: memalign (vg_replace_malloc.c:727)
> ==11740==    by 0x4CF3D2D: PetscMallocAlign (mal.c:27)
> ==11740==    by 0x4CF5914: PetscTrMallocDefault (mtr.c:189)
> ==11740==    by 0x4D5A0D4: PetscObjectComposedDataIncreaseReal
> (state.c:171)
> ==11740==    by 0x5830E97: PCGAMGOptprol_AGG (agg.c:1320)
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130923/4321c9af/attachment.html>
