[petsc-dev] build errror
Mark F. Adams mfadams at lbl.gov
Sat Sep 21 18:03:34 CDT 2013
Well, this is getting hard to reproduce so I'm going back to the beginning:
  711  git checkout master
  712  git pull
  713  rm -fr arch-macosx-gnu-O
  714  ./arch-macosx-gnu-O.py
and I get this error.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130921/1a312f0f/attachment.obj>
On Sep 21, 2013, at 5:25 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> "Mark F. Adams" <mfadams at lbl.gov> writes:
>>>> $ make -f gmakefile PETSC_ARCH=arch-macosx-gnu-O
>> OK, I'm up and running.  Do I need to use this -f flag all the time or can I configure something?
> You haven't told us what happens when you try a parallel build while
> invoking make directly or when you set MAKE_NP=1 to prevent a parallel
> build.
