[petsc-dev] build errror
Mark F. Adams
mfadams at lbl.gov
Sat Sep 21 17:42:30 CDT 2013
On Sep 21, 2013, at 5:25 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> "Mark F. Adams" <mfadams at lbl.gov> writes:
>>>> $ make -f gmakefile PETSC_ARCH=arch-macosx-gnu-O
>> OK, I'm up and running. Do I need to use this -f flag all the time or can I configure something?
> You haven't told us what happens when you try a parallel build while
> invoking make directly or when you set MAKE_NP=1 to prevent a parallel
> build.
'make MAKE_NP=1' seems to work (as well as Satish's -j 8) … but damn it, just plane 'make all' works now.
Jed: is 'make MAKE_NP=1' what you wanted me to test?
I deleted the ARCH directory and reconfigured and got the same error with 'make all'.
I then did 'make -f gmakefile -j 8' and that worked. I'm going to clean and make super sure that two ''make all" do not work and that a clean 'make -f gmakefile -j 8' works.
