[petsc-dev] build errror
Sat Sep 21 16:25:33 CDT 2013
"Mark F. Adams" <mfadams at lbl.gov> writes:
>>> $ make -f gmakefile PETSC_ARCH=arch-macosx-gnu-O
> OK, I'm up and running.  Do I need to use this -f flag all the time or can I configure something?
You haven't told us what happens when you try a parallel build while
invoking make directly or when you set MAKE_NP=1 to prevent a parallel
build.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130921/48438e7f/attachment.sig>
