[petsc-dev] Petsc configuration
Barry Smith
bsmith at mcs.anl.gov
Sat Sep 21 10:26:52 CDT 2013
On Sep 21, 2013, at 9:32 AM, Jose David Bermeol <jbermeol at purdue.edu> wrote:
> Hi, I've been cheking your configuration strategy,and I have one question, if I add the flag --with-package-dir=$LOCATION. Petsc is going to look in the folders $LOCATION/lib and $LOCATION/include. How could I change that such that it search the library in a set of folders inside $LOCATION/lib??
> Thanks.
The class you are writing in cPardiso.py is a subclass of PETSc.package.NewPackage
class Configure(PETSc.package.NewPackage):
which is a subclass of BuildSystem.config.Package which is defined in config/BuildSystem/config/Package.py
thus you can overwrite any data/method in these classes by simply putting your modified data/method into your cPardiso.py
1) If you want to look in only ONE or TWO locations inside the package-dir directory somewhere you can just reset
self.libdir = 'lib' # location of libraries in the package directory tree
self.altlibdir = 'lib64' # alternate location of libraries in the package directory tree
2) If you have a big list of possible places to check we don't have a way to simply provide them all but you can provide your own
def generateGuesses(self):
Just copy the one from Package.py and edit it as needed; note lots of ours are for cases you do not care have (--download and pkg-config) etc and you can just strip that out of your version so your version will likely end up being only a few lines.
Barry
