[petsc-dev] Petsc configuration
Sat Sep 21 09:48:41 CDT 2013
Jose David Bermeol <jbermeol at purdue.edu> writes:
> Hi, I've been cheking your configuration strategy,and I have one
> question, if I add the flag --with-package-dir=$LOCATION. Petsc is
> going to look in the folders $LOCATION/lib and $LOCATION/include. How
> could I change that such that it search the library in a set of
> folders inside $LOCATION/lib??
You can use --with-package-lib=/path/to/lib and
--with-package-include=/path/to/include if you have an unconventional
path layout.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130921/08d85ab7/attachment.sig>
