[petsc-dev] build errror
Mark F. Adams
mfadams at lbl.gov
Sat Sep 21 10:11:03 CDT 2013
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130921/4a54d6f3/attachment.obj>
On Sep 21, 2013, at 10:12 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Sat, 21 Sep 2013, Mark F. Adams wrote:
>> I'm building on a branch merged with jed/object-id like so:
>> git merge origin/jed/object-id
>> 675 rm -fr arch-macosx-gnu-O
>> 676 ./arch-macosx-gnu-O.py
>> 677 make PETSC_DIR=/Users/markadams/Codes/petsc PETSC_ARCH=arch-macosx-gnu-O all
>> and get these errors,
>> Mark
> CC arch-macosx-gnu-O/obj/src/sys/logging/utils/classlog.o
> CC arch-macosx-gnu-O/obj/src/sys/logging/utils/stagelog.o
> CC arch-macosx-gnu-O/obj/src/sys/logging/utils/eventlog.o
> CC arch-macosx-gnu-O/obj/src/sys/logging/utils/stack.o
> CC arch-macosx-gnu-O/obj/src/sys/classes/viewer/impls/binary/binv.o
> gmake[1]: *** [gnumake] Error 141
> ^[[1;31m**************************ERROR************************************
> Error during compile, check arch-macosx-gnu-O/conf/make.log
> Send it and arch-macosx-gnu-O/conf/configure.log to petsc-maint at mcs.anl.gov
> ********************************************************************^[[0;39m^[[0;49m
> Hm - there is no error message in there. Can you retry make with 'V=1' and see
> if there is a better message?
> make PETSC_DIR=/Users/markadams/Codes/petsc PETSC_ARCH=arch-macosx-gnu-O all V=1
> Satish
