[petsc-dev] build errror
Satish Balay
balay at mcs.anl.gov
Sat Sep 21 09:12:00 CDT 2013
On Sat, 21 Sep 2013, Mark F. Adams wrote:
> I'm building on a branch merged with jed/object-id like so:
> git merge origin/jed/object-id
> 675 rm -fr arch-macosx-gnu-O
> 676 ./arch-macosx-gnu-O.py
> 677 make PETSC_DIR=/Users/markadams/Codes/petsc PETSC_ARCH=arch-macosx-gnu-O all
> and get these errors,
> Mark
CC arch-macosx-gnu-O/obj/src/sys/logging/utils/classlog.o
CC arch-macosx-gnu-O/obj/src/sys/logging/utils/stagelog.o
CC arch-macosx-gnu-O/obj/src/sys/logging/utils/eventlog.o
CC arch-macosx-gnu-O/obj/src/sys/logging/utils/stack.o
CC arch-macosx-gnu-O/obj/src/sys/classes/viewer/impls/binary/binv.o
gmake[1]: *** [gnumake] Error 141
^[[1;31m**************************ERROR************************************
Error during compile, check arch-macosx-gnu-O/conf/make.log
Send it and arch-macosx-gnu-O/conf/configure.log to petsc-maint at mcs.anl.gov
********************************************************************^[[0;39m^[[0;49m
Hm - there is no error message in there. Can you retry make with 'V=1' and see
if there is a better message?
make PETSC_DIR=/Users/markadams/Codes/petsc PETSC_ARCH=arch-macosx-gnu-O all V=1
Satish
