[petsc-dev] coarse grid in gamg (for the OPTE paper)
Mark F. Adams mfadams at lbl.gov
Thu Sep 19 16:28:58 CDT 2013
On Sep 19, 2013, at 3:53 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   It is essentially 3 Laplacians
If you mean literally 3 scalar laplacians packed in one matrix for some reason then the one constant vector is fine.  Is this a block diagonal matrix with 3 big blocks, if you order it correctly of course?
> so I think the default null space of 3 constant vectors is fine.
You get this if you set the block size to 3.  Constant vectors in each of the three components.
> The problem is without the block information presumably GAMG is using only a single constant vector over all variables?  So maybe we need to construct a 3 vector null space which just marks in the reduced vector from which of the 3 components each entry came from.
>   Barry
> On Sep 19, 2013, at 3:48 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>  That is what it is doing and apparently it doesn't result in a good
>>>  preconditioner; I don't know why off hand. One thing is it no
>>>  longer knows about the block structure.
>> How is the near null space being specified?
