[petsc-dev] Petsc test
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Sep 18 21:33:18 CDT 2013
  Same ones. Why would the special case of one process be some different code?
   Barry
On Sep 18, 2013, at 8:38 PM, Jose David Bermeol <jbermeol at purdue.edu> wrote:
> Hi and for MATSEQAIJ
> Thanks
> From: "Barry Smith" <bsmith at mcs.anl.gov>
> To: "Jose David Bermeol" <jbermeol at purdue.edu>
> Cc: petsc-dev at mcs.anl.gov
> Sent: Tuesday, September 17, 2013 8:48:59 AM
> Subject: Re: [petsc-dev] Petsc test
>   I would suggest src/snes/examples/tutorials/ex19.c as a two dimensional mesh problem. You can run with -da_refine n   where n is 2, 3, 4, … etc to create larger problems.
> For three dimensions you can use src/ksp/ksp/examples/tutorials/ex45.c  again -da_refine 1,2,3,… increases the problem size
>   Barry
> On Sep 16, 2013, at 8:23 PM, Jose David Bermeol <jbermeol at purdue.edu> wrote:
>> Hi, I'm testing my Matsolver that uses pardico for MATMPIAIJ matrices, I want to know if you have a set of test for solvers and tests for scalability(to do benchmarking).
>> Thanks
