[petsc-dev] master breaking with gmake
Tue Sep 17 13:43:52 CDT 2013
~/Src/petsc  barry/fix-petscobjectsetstate $ gmake --version
GNU Make 3.82
Built for x86_64-apple-darwin10.8.0
Copyright (C) 2010  Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
[ 15%] Building C object CMakeFiles/petsc.dir/src/sys/classes/draw/utils/ftn-custom/zaxisf.c.o
[ 15%] [ 15%] Building C object CMakeFiles/petsc.dir/src/sys/classes/draw/utils/ftn-custom/zzoomf.c.o
Building C object CMakeFiles/petsc.dir/src/sys/classes/random/interface/ftn-auto/randomcf.c.o
[ 15%] Building C object CMakeFiles/petsc.dir/src/sys/classes/random/interface/ftn-auto/randomf.c.o
[ 15%] [ 15%] Building C object CMakeFiles/petsc.dir/src/sys/classes/random/interface/ftn-custom/zrandomf.c.o
Building Fortran object CMakeFiles/petsc.dir/src/sys/fsrc/somefort.F.o
[ 15%] Building C object CMakeFiles/petsc.dir/src/sys/time/ftn-auto/cputimef.c.o
[ 15%] Building C object CMakeFiles/petsc.dir/src/sys/time/ftn-custom/zptimef.c.o
[ 16%] [ 16%] Building C object CMakeFiles/petsc.dir/src/sys/threadcomm/impls/pthread/tcpthread.c.o
Building C object CMakeFiles/petsc.dir/src/sys/threadcomm/impls/pthread/tclockfree.c.o
[ 16%] [ 16%] Building C object CMakeFiles/petsc.dir/src/vec/is/utils/ftn-auto/isltogf.c.o
Building C object CMakeFiles/petsc.dir/src/vec/is/utils/ftn-auto/vsectionisf.c.o
[ 16%] Building C object CMakeFiles/petsc.dir/src/vec/is/is/impls/stride/ftn-auto/stridef.c.o
gmake[3]: *** read jobs pipe: No such file or directory.  Stop.
gmake[3]: *** Waiting for unfinished jobs....
[ 16%] Building C object CMakeFiles/petsc.dir/src/vec/is/is/impls/block/ftn-auto/blockf.c.o
gmake[2]: *** [CMakeFiles/petsc.dir/all] Broken pipe: 13
gmake[1]: *** [all] Error 2
gmake[1]: INTERNAL: Exiting with 1 jobserver tokens available; should be 7!
make: *** [ccmake] Error 2
Compilation exited abnormally with code 2 at Tue Sep 17 13:41:43
