[petsc-dev] Join A and B seq matrices of a mpi matrix.
Jose David Bermeol jbermeol at purdue.edu
Tue Sep 17 17:35:40 CDT 2013
Hi, right now I'm coding a solver for MATMPIAIJ matrices, as you know this kind of matrix has a diagonal matrix A of size n x n and a matrix B with the off-diagonal matrices of size n x (N - n). The problem is that my solver for each MPI process receive 3 arrays that represents the rows in the MPI process(aij format), that means the complete n x N matrix.
What I did was a join of the A and B matrix, however this implies almost to duplicate everything in memory.
I don't know if you know a better strategy for this(less memory overhead). Thanks
Here is my code if you see something that can be improve:
 * MATMPIAIJ matrices are divided in two matrices,
 * diagonal matrix(A) and off-diagonal matrix(B),
 * both in aij format, as cpardiso only recives one matrix,
 * this method will join A and B matrix in one, return aij
 * representation and number of non-zero elements.
 * This method will copy(duplicate) A and B elements in a new matrix.
 * Input:
 * 		- Mat A: MATMPIAIJ matrix
 * 		- int shift: matrix index.(cpardiso requires fortan indexing)
 * 			- 0 for c representation
 * 			- 1 for fortran representation
 * 		- MatReuse reuse:
 * 			- MAT_INITIAL_MATRIX: Create a new aij representation
 * 			- MAT_REUSE_MATRIX: Reuse all aij representation and just change values
 * 	Output:
 * 		- int *nnz: Number of nonzero-elements.
 * 		- int **r pointer to i index
 * 		- int **c pointer to j elements
 * 		- PetscScalar **v: Non-zero elements
#undef __FUNCT__
#define __FUNCT__ "MatJoin_CPARDISO"
PetscErrorCode MatJoin_CPARDISO(Mat A, int shift, MatReuse reuse, int *nnz, int **r, int **c, PetscScalar **v){
  const PetscInt    *ai, *aj, *bi, *bj, *garray, m=A->rmap->n, *ajj, *bjj;
  PetscErrorCode    ierr;
  PetscInt          rstart, nz, i, jj, countA, countB, idxA, idxB;
  PetscInt          *row,*col;
  const PetscScalar *av, *bv,*v1,*v2;
  PetscScalar       *val;
  Mat_MPIAIJ        *mat = (Mat_MPIAIJ*)A->data;
  Mat_SeqAIJ        *aa  = (Mat_SeqAIJ*)(mat->A)->data;
  Mat_SeqAIJ        *bb  = (Mat_SeqAIJ*)(mat->B)->data;
  PetscFunctionBegin;
  ai=aa->i; aj=aa->j; bi=bb->i; bj=bb->j; rstart= A->rmap->rstart;
  av=aa->a; bv=bb->a;
  garray = mat->garray;
  if (reuse == MAT_INITIAL_MATRIX) {
    nz   = aa->nz + bb->nz;
    *nnz = nz;
    ierr = PetscMalloc(((nz + m + 1)*sizeof(PetscInt) + nz*sizeof(PetscScalar)), &row);CHKERRQ(ierr);
    col  = row + m + 1;
    val  = (PetscScalar*)(col + nz);
    *r = row; *c = col; *v = val;
  } else {
    row = *r; col = *c; val = *v;
  jj = 0;
  for (i=0; i<m; i++) {
    countA = ai[i+1] - ai[i];
    countB = bi[i+1] - bi[i];
    ajj    = aj + ai[i];
    bjj    = bj + bi[i];
    v1     = av + ai[i];
    v2     = bv + bi[i];
    if(reuse == MAT_INITIAL_MATRIX){
      row[i] = jj + shift;
    idxA = 0; idxB = 0;
    if(countA + countB == 0){
    } else if(countB == 0){
      for (idxA = 0; idxA < countA; idxA++) {
          col[jj] = rstart + ajj[idxA] + shift;
        val[jj] = v1[idxA];
        jj++;
    } else if(countA == 0){
      for (idxB = 0; idxB < countB; idxB++) {
          col[jj] = garray[bjj[idxB]] + shift;
        val[jj] = v2[idxB];
        jj++;
    } else {
      while(rstart + ajj[idxA] > garray[bjj[idxB]]){
        val[jj] = v2[idxB];
    	idxB++;
    	jj++;
        val[jj] = v1[idxA];
  	jj++;
      for (; idxB < countB; idxB++) {
        val[jj] = v2[idxB];
        jj++;
    row[m] = jj + shift;
  PetscFunctionReturn(0);
