[petsc-dev] Vec distribution
Sat Sep 14 20:10:10 CDT 2013
On Sat, Sep 14, 2013 at 5:55 PM, Jose David Bermeol <jbermeol at purdue.edu>wrote:
> Hi, right now I'm implementing the function MatSolve for MATMPIAIJ
> matrices, so I can assume that output vector x is an MPI vector. the
> problem is that my library returns the solution in an array to all my MPI
> process, so how do I know which elements of the solution should be safe in
> the local vector x.
I do not understand what you are asking. However, each Vec is divided
across processes by contiguous sets of rows. The rows
for a given process can be gotten from VecGetOwnershipRange().
   Matt
> Thanks
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130914/bda06f6b/attachment.html>
