[petsc-dev] Vec distribution
Jose David Bermeol jbermeol at purdue.edu
Sat Sep 14 19:55:29 CDT 2013
Hi, right now I'm implementing the function MatSolve for MATMPIAIJ matrices, so I can assume that output vector x is an MPI vector. the problem is that my library returns the solution in an array to all my MPI process, so how do I know which elements of the solution should be safe in the local vector x.
Thanks
