[petsc-dev] MATMPIAIJ and MATMPIBAIJ
    Satish Balay
    balay at mcs.anl.gov
    Fri Sep 13 14:30:30 CDT 2013
On Fri, 13 Sep 2013, Jose David Bermeol wrote:
> Hi it may be a silly question, but what is the difference between MATMPIAIJ and MATMPIBAIJ, the manual is a bit technical, so if you could answer in simple words or maybe with an example would be great.
sparse matrix vs 'block' sparse matrix.
Internal representation is (row,col,val)   vs (block-row, block-col, block-of-values [say 2x2 = 4 values])
Satish
