[petsc-dev] MATMPIAIJ and MATMPIBAIJ
Jose David Bermeol jbermeol at purdue.edu
Fri Sep 13 13:53:53 CDT 2013
Hi it may be a silly question, but what is the difference between MATMPIAIJ and MATMPIBAIJ, the manual is a bit technical, so if you could answer in simple words or maybe with an example would be great.
Thanks
