[petsc-dev] sor smoothers
Barry Smith
bsmith at mcs.anl.gov
Thu Sep 12 18:44:08 CDT 2013
No system is perfect. I was just pointing out that the model we selected was dictated by one particularly bad fortran compiler design decision and atheistically I don't like it. I was not proposing a change.
On Sep 12, 2013, at 6:39 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>> My solution was that the those "defaults" would not be in the public
>> interface :-)
> Fine, get rid of all of these:
> $ git grep '[a-z]Default(' include/*.h
> include/petscerror.h:PETSC_EXTERN PetscErrorCode PetscSignalHandlerDefault(int,void*);
> include/petscksp.h:PETSC_EXTERN PetscErrorCode KSPBuildSolutionDefault(KSP,Vec,Vec*);
> include/petscksp.h:PETSC_EXTERN PetscErrorCode KSPBuildResidualDefault(KSP,Vec,Vec,Vec *);
> include/petscksp.h:PETSC_EXTERN PetscErrorCode KSPDestroyDefault(KSP);
> include/petscksp.h:PETSC_EXTERN PetscErrorCode KSPMonitorDefault(KSP,PetscInt,PetscReal,void *);
> include/petscksp.h:PETSC_EXTERN PetscErrorCode KSPLSQRMonitorDefault(KSP,PetscInt,PetscReal,void *);
> include/petscksp.h:PETSC_EXTERN PetscErrorCode KSPConvergedDefault(KSP,PetscInt,PetscReal,KSPConvergedReason*,void *);
> include/petscksp.h:PETSC_DEPRECATED("Use KSPConvergedDefault()") PETSC_STATIC_INLINE void KSPDefaultConverged(void) { /* never called */ }
> include/petscoptions.h:PETSC_EXTERN PetscErrorCode PetscOptionsMonitorDefault(const char[], const char[], void *);
> include/petscpc.h:PETSC_EXTERN PetscErrorCode PCMGResidualDefault(Mat,Vec,Vec,Vec);
> include/petscsnes.h:PETSC_EXTERN PetscErrorCode SNESMonitorDefault(SNES,PetscInt,PetscReal,void *);
> include/petscsnes.h:PETSC_EXTERN PetscErrorCode SNESConvergedDefault(SNES,PetscInt,PetscReal,PetscReal,PetscReal,SNESConvergedReason*,void*);
> include/petscsnes.h:PETSC_EXTERN PetscErrorCode SNESComputeJacobianDefault(SNES,Vec,Mat*,Mat*,MatStructure*,void*);
> include/petscsys.h:PETSC_EXTERN PetscErrorCode PetscVFPrintfDefault(FILE*,const char[],va_list);
> include/petscsys.h:PETSC_EXTERN PetscErrorCode PetscErrorPrintfDefault(const char [],...);
> include/petscsys.h:PETSC_EXTERN PetscErrorCode PetscHelpPrintfDefault(MPI_Comm,const char [],...);
> include/petscts.h:PETSC_EXTERN PetscErrorCode TSMonitorDefault(TS,PetscInt,PetscReal,Vec,void*);
> include/petscts.h:PETSC_EXTERN PetscErrorCode TSPseudoTimeStepDefault(TS,PetscReal*,void*);
> include/petscts.h:PETSC_EXTERN PetscErrorCode TSPseudoVerifyTimeStepDefault(TS,Vec,void*,PetscReal*,PetscBool *);
> include/petscts.h:PETSC_EXTERN PetscErrorCode TSAlphaAdaptDefault(TS,PetscReal,Vec,Vec,PetscReal*,PetscBool*,void*);
> Note that removing the default would make it impossible to "reset" one
> of these functions after some user chose a non-default callback.
>> I know, I know you have some reason to have them be in the public
>> interface. But it is not a good enough reason to have function
>> names that are not "natural" :-)
> You added many of those functions and you renamed a bunch of them
> recently.
