[petsc-dev] sor smoothers
Barry Smith
bsmith at mcs.anl.gov
Thu Sep 12 18:05:39 CDT 2013
Jed did not like the _ in it. I liked it :-(
On Sep 12, 2013, at 5:19 PM, "Mark F. Adams" <mfadams at lbl.gov> wrote:
> And there is already:
> PETSC_DEPRECATED("Use PCMGResidualDefault()") PETSC_STATIC_INLINE PetscErrorCode PCMGResidual_Default(Mat A,Vec b,Vec x,Vec r) {
> return PCMGResidualDefault(A,b,x,r);
> Should I assume PCMGResidualDefault is dead and change this to:
> PETSC_DEPRECATED("Use MatResidualDefault()") PETSC_STATIC_INLINE PetscErrorCode PCMGResidualDefault(Mat A,Vec b,Vec x,Vec r) {
> On Sep 12, 2013, at 5:46 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Sep 12, 2013, at 4:39 PM, "Mark F. Adams" <mfadams at lbl.gov> wrote:
>>> I'm not sure what to do with:
>>> PetscErrorCode PCMGSetResidual(PC pc,PetscInt l,PetscErrorCode (*residual)(Mat,Vec,Vec,Vec),Mat mat) ?
>>> I'm thinking to have this in the code:
>>> mglevels[l]->A = mat;
>>> mglevels[l]->residual = residual;
>>> and change the calls from using PCMGResidualDefault to using MatResidualDefault.
>> Seems ok to me.
>>> This will keep from breaking code that uses this to set the Mat also. And should this be called PCMGSetResidualAndMat?
>> No.
>> Barry
>>> Mark
>>> On Sep 9, 2013, at 9:25 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> On Sep 9, 2013, at 8:03 PM, "Mark F. Adams" <mfadams at lbl.gov> wrote:
>>>>> OK, so its ground hog day. The plan?:
>>>>> 1) I should add a residual method to Mat, make a MatResidualDefault, and have all (yuck) SetUp_MatXXX set this default. I guess there is no base class SetUp …. then make a MatResidual_SeqAIJ that just does a dumb residual for now, with testing logic if Jed's stuff is available.
>>>> Take a look at MatCreate_SeqAIJ. These fill up all the function points in one swoop with the big function table, this is why there is not "base class setup".
>>>>> 2) Have PCMGResidualDefault call MatResidual instead MatMult & VecAYPX. Or do we want to nuke PCMGResidualDefault?
>>>> You don't really need PCMGResidualDefault, just make the residual function pointer in PCMG point to MatResidual
>>>>> Jed's defect correction argument might sound like a typical Jed, e.g., what if a Martian gets hepatitis during mardi gras, but defect correction is really useful and I would like to see its support supported …
>>>> Don't need it to support defect correction but anyways :-)
>>>>> 3) Add fields in Mat: mat_res_state, vec_res_state, vec_res_id. I need to know the types but I can do this in the next phase.
>>>> Look in _p_PetscObject for the types of state and id, both currently PetscInt.
>>>>> Mark
>>>>> On Sep 9, 2013, at 5:35 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>>> On Sep 9, 2013, at 4:32 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>>>>>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>>>>>> I don't care if PCMGSetResidual stays around for now but I do not
>>>>>>>> think we should "point to it" as a standard way for people to do
>>>>>>>> things; I think we should improve how the two slots are used with
>>>>>>>> PCMG, it really has never been thought about at all and whenever
>>>>>>>> possible I think using the two slots appropriately is better than
>>>>>>>> PCMGSetResidual and will solve most of the "use" cases.
>>>>>>> Fine, I was just not eager to _delete_ PCMGSetResidual until we had
>>>>>>> established a complete replacement, and even then, it might be enough to
>>>>>>> leave it as "advanced" and suggest the preferred alternative in the man
>>>>>>> page. It just doesn't seem expensive to support and I don't think it
>>>>>>> causes people to tangle themselves up in bad design.
>>>>>> It doesn't have its own object which is kind of limiting.
