[petsc-dev] sor smoothers
Mark F. Adams
mfadams at lbl.gov
Thu Sep 12 17:19:37 CDT 2013
And there is already:
PETSC_DEPRECATED("Use PCMGResidualDefault()") PETSC_STATIC_INLINE PetscErrorCode PCMGResidual_Default(Mat A,Vec b,Vec x,Vec r) {
return PCMGResidualDefault(A,b,x,r);
Should I assume PCMGResidualDefault is dead and change this to:
PETSC_DEPRECATED("Use MatResidualDefault()") PETSC_STATIC_INLINE PetscErrorCode PCMGResidualDefault(Mat A,Vec b,Vec x,Vec r) {
On Sep 12, 2013, at 5:46 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 12, 2013, at 4:39 PM, "Mark F. Adams" <mfadams at lbl.gov> wrote:
>> I'm not sure what to do with:
>> PetscErrorCode PCMGSetResidual(PC pc,PetscInt l,PetscErrorCode (*residual)(Mat,Vec,Vec,Vec),Mat mat) ?
>> I'm thinking to have this in the code:
>> mglevels[l]->A = mat;
>> mglevels[l]->residual = residual;
>> and change the calls from using PCMGResidualDefault to using MatResidualDefault.
> Seems ok to me.
>> This will keep from breaking code that uses this to set the Mat also. And should this be called PCMGSetResidualAndMat?
> No.
> Barry
>> Mark
>> On Sep 9, 2013, at 9:25 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On Sep 9, 2013, at 8:03 PM, "Mark F. Adams" <mfadams at lbl.gov> wrote:
>>>> OK, so its ground hog day. The plan?:
>>>> 1) I should add a residual method to Mat, make a MatResidualDefault, and have all (yuck) SetUp_MatXXX set this default. I guess there is no base class SetUp …. then make a MatResidual_SeqAIJ that just does a dumb residual for now, with testing logic if Jed's stuff is available.
>>> Take a look at MatCreate_SeqAIJ. These fill up all the function points in one swoop with the big function table, this is why there is not "base class setup".
>>>> 2) Have PCMGResidualDefault call MatResidual instead MatMult & VecAYPX. Or do we want to nuke PCMGResidualDefault?
>>> You don't really need PCMGResidualDefault, just make the residual function pointer in PCMG point to MatResidual
>>>> Jed's defect correction argument might sound like a typical Jed, e.g., what if a Martian gets hepatitis during mardi gras, but defect correction is really useful and I would like to see its support supported …
>>> Don't need it to support defect correction but anyways :-)
>>>> 3) Add fields in Mat: mat_res_state, vec_res_state, vec_res_id. I need to know the types but I can do this in the next phase.
>>> Look in _p_PetscObject for the types of state and id, both currently PetscInt.
>>>> Mark
>>>> On Sep 9, 2013, at 5:35 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>> On Sep 9, 2013, at 4:32 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>>>>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>>>>> I don't care if PCMGSetResidual stays around for now but I do not
>>>>>>> think we should "point to it" as a standard way for people to do
>>>>>>> things; I think we should improve how the two slots are used with
>>>>>>> PCMG, it really has never been thought about at all and whenever
>>>>>>> possible I think using the two slots appropriately is better than
>>>>>>> PCMGSetResidual and will solve most of the "use" cases.
>>>>>> Fine, I was just not eager to _delete_ PCMGSetResidual until we had
>>>>>> established a complete replacement, and even then, it might be enough to
>>>>>> leave it as "advanced" and suggest the preferred alternative in the man
>>>>>> page. It just doesn't seem expensive to support and I don't think it
>>>>>> causes people to tangle themselves up in bad design.
>>>>> It doesn't have its own object which is kind of limiting.
