[petsc-dev] sor smoothers
Mark F. Adams
mfadams at lbl.gov
Mon Sep 9 20:03:07 CDT 2013
OK, so its ground hog day. The plan?:
1) I should add a residual method to Mat, make a MatResidualDefault, and have all (yuck) SetUp_MatXXX set this default. I guess there is no base class SetUp …. then make a MatResidual_SeqAIJ that just does a dumb residual for now, with testing logic if Jed's stuff is available.
2) Have PCMGResidualDefault call MatResidual instead MatMult & VecAYPX. Or do we want to nuke PCMGResidualDefault? Jed's defect correction argument might sound like a typical Jed, e.g., what if a Martian gets hepatitis during mardi gras, but defect correction is really useful and I would like to see its support supported ...
3) Add fields in Mat: mat_res_state, vec_res_state, vec_res_id. I need to know the types but I can do this in the next phase.
On Sep 9, 2013, at 5:35 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 9, 2013, at 4:32 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>> I don't care if PCMGSetResidual stays around for now but I do not
>>> think we should "point to it" as a standard way for people to do
>>> things; I think we should improve how the two slots are used with
>>> PCMG, it really has never been thought about at all and whenever
>>> possible I think using the two slots appropriately is better than
>>> PCMGSetResidual and will solve most of the "use" cases.
>> Fine, I was just not eager to _delete_ PCMGSetResidual until we had
>> established a complete replacement, and even then, it might be enough to
>> leave it as "advanced" and suggest the preferred alternative in the man
>> page. It just doesn't seem expensive to support and I don't think it
>> causes people to tangle themselves up in bad design.
> It doesn't have its own object which is kind of limiting.
