[petsc-dev] Extend Petsc to uses Pardiso
Jose David Bermeol jbermeol at purdue.edu
Mon Sep 9 17:49:05 CDT 2013
Hi again, one more question, what should be the difference between MatLUFactorSymbolic and MatLUFactorNumeric?
Thanks
----- Original Message -----
From: "Jose David Bermeol" <jbermeol at purdue.edu>
To: petsc-dev at mcs.anl.gov
Sent: Monday, September 2, 2013 6:42:43 PM
Subject: Extend Petsc to uses Pardiso
Hi, right now I'm trying to extend Petsc to be able to solve linear system of equations(Ax = b) using Pardiso for LU decomposition. So I have a couple of questions:
1. What is the difference between the methods MatSolve and KSPSolve. And in which context should I use each?
2. Should I extend the KSP interface or the Mat interface, or what factors I have to take into account to make my decision?.
For now that would be all.
Thanks
