[petsc-dev] sor smoothers
Barry Smith
bsmith at mcs.anl.gov
Sun Sep 8 16:18:36 CDT 2013
On Sep 8, 2013, at 4:09 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>> I actually like having the typedefs in these situations even if
>> there is a portable alternative. It makes it clear what the purpose
>> of the variable is, if everything is just labeled double, int or
>> long int you don't know immediately what it represents. For example
>> PetscErrorCode and PetscLogDouble (maybe a bad name) or
>> PetscClassId. We started with int for PetscErrorCode and I found
>> changing it really clarified the source code.
>> For these we could use PetscObjectState, PetscObjectId, or something
>> else.
> I have no problem with typedefs based on _intent_, but it may be that
> Petsc64bitUInt is unnecessary. If stdint.h is now ubiquitious enough,
> then we just use
> typedef uint64_t PetscObjectId;
Sure, this is just a configure/what systems people are using now issue.
I do note that in my reading Microsoft NEVER plans to support C99 (except parts that are in the C++ standards) so we can never switch to C99? http://herbsutter.com/2012/05/03/reader-qa-what-about-vc-and-c99/
Barry
