[petsc-dev] sor smoothers
Sun Sep 8 16:09:42 CDT 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>    I actually like having the typedefs in these situations even if
>    there is a portable alternative. It makes it clear what the purpose
>    of the variable is, if everything is just labeled double, int or
>    long int you don't know immediately what it represents. For example
>    PetscErrorCode and PetscLogDouble (maybe a bad name) or
>    PetscClassId.  We started with int for PetscErrorCode and I found
>    changing it really clarified the source code.
>   For these we could use PetscObjectState, PetscObjectId, or something
>   else.
I have no problem with typedefs based on _intent_, but it may be that
Petsc64bitUInt is unnecessary.  If stdint.h is now ubiquitious enough,
then we just use
  typedef uint64_t PetscObjectId;
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130908/7e8ca6cc/attachment.sig>
