[petsc-dev] PetscIntialize docs
Satish Balay
balay at mcs.anl.gov
Thu Sep 5 14:29:04 CDT 2013
On Thu, 5 Sep 2013, Mark F. Adams wrote:
> On Sep 5, 2013, at 12:46 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >>> I wanted to not have files get checked and added -skip_petscrc to
> >>> the command line but this was not sufficient. I needed to change
> >>> the code to use NULL (or I told my user to do so).
> > Was 'useroptfile' causing some problem - or is it that you wanted to
> > avoid it for some other reason?
> This was the problem with Mira that we went through with Jeff H. last week. Where getting the home directory was failing occasionally and hanging the system. So I was told to use -skip_petscrc on the command line, which failed to get the code to skip the (user) RC file.
But did the code hang or crash?
Satish
> In looking at the code I realized that you need to not give PetscInitialize() an RC file name. So we need to change the code slightly but it took a while to figure that out (e.g., I had to look at the source).
> > thanks,
> > Satish
