[petsc-dev] PetscIntialize docs
    Satish Balay
    balay at mcs.anl.gov
    Thu Sep  5 11:46:56 CDT 2013
On Thu, 5 Sep 2013, Satish Balay wrote:
> On Thu, 5 Sep 2013, Mark F. Adams wrote:
> > I wanted to not have files get checked and added -skip_petscrc to
> > the command line but this was not sufficient.  I needed to change
> > the code to use NULL (or I told my user to do so).
Was 'useroptfile' causing some problem - or is it that you wanted to
avoid it for some other reason?
thanks,
Satish
