[petsc-dev] [petsc-maint] valgrind detected on /usr/local/include and enabled but header files from this dir are not added to build path
    Matthew Knepley
    knepley at gmail.com
    Wed Oct 30 13:16:17 CDT 2013
On Wed, Oct 30, 2013 at 1:15 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 30 Oct 2013, Satish Balay wrote:
> Ok - I have the following ready for comments - so its in the pull
> request queue.
> https://bitbucket.org/petsc/petsc/branch/balay/move-externalpackages-dir
> - move externalpackages location to PETSC_DIR/PETSC_ARCH
> - add '--with-clean' to delete PETSC_DIR/PETSC_ARCH at the begining of the
> build.
> Outstanding issue: Should we remove --with-externalpackages-dir option
> or keep it?
Remove it.
  Matt
> Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131030/89091f4b/attachment.html>
