[petsc-dev] [petsc-maint] valgrind detected on /usr/local/include and enabled but header files from this dir are not added to build path
    Satish Balay
    balay at mcs.anl.gov
    Wed Oct 30 13:15:14 CDT 2013
On Wed, 30 Oct 2013, Satish Balay wrote:
Ok - I have the following ready for comments - so its in the pull
request queue.
https://bitbucket.org/petsc/petsc/branch/balay/move-externalpackages-dir
- move externalpackages location to PETSC_DIR/PETSC_ARCH
- add '--with-clean' to delete PETSC_DIR/PETSC_ARCH at the begining of the build.
Outstanding issue: Should we remove --with-externalpackages-dir option
or keep it?
Satish
