[petsc-dev] [petsc-maint] valgrind detected on	/usr/local/include and enabled but header files from this dir	are not added to build path
    Jed Brown
    jedbrown at mcs.anl.gov
    Tue Oct 29 23:05:57 CDT 2013
Matthew Knepley <knepley at gmail.com> writes:
> I do not think this is an important corner case.
It happens periodically, maybe once every few months on petsc-maint.
> Because you can end up with an incompatible mix of stubs. The build
> may crash even though the stub generation process will not.
If the working tree is changing while generating the stubs, no amount of
locking will fix it.  If the working tree is not changing, all generator
processes should produce the same result.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131029/479c3d02/attachment.sig>
