[petsc-dev] [petsc-maint] valgrind detected on /usr/local/include and enabled but header files from this dir are not added to build path
Tue Oct 29 16:30:46 CDT 2013
On Tue, Oct 29, 2013 at 4:12 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > I see fooling with dependencies as a good thing in general to simplify
> > things, but having not
> > much to do with what Jed wants. We can easily buffer till kingdom come.
> The only reason I don't want to buffer too long is so that we don't have
> too much history going into the error message.
> One possible problem with buffering forever is that if the disk fills up
> while configure is running, we won't be able to write configure.log to
> report the error without first freeing up space (and since we might not
> be the only process filling up the disk, even that isn't guaranteed to
> work).
I do not think this is an important corner case.
> >> No locking, just commit the results atomically.  That means write a
> >> temporary file and rename it to replace the existing file.  (Or checksum
> >> and just delete the tmp file if they match, so that modification times
> >> don't change.)
> > This is not good enough for the stubs.
> Just because sowing is extremely file-based or for a real reason?
Because you can end up with an incompatible mix of stubs. The build may
crash
even though the stub generation process will not.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131029/7a671eb5/attachment.html>
