[petsc-dev] [petsc-maint] valgrind detected on /usr/local/include and enabled but header files from this dir are not added to build path
    Satish Balay
    balay at mcs.anl.gov
    Tue Oct 29 17:33:40 CDT 2013
On Tue, 29 Oct 2013, Satish Balay wrote:
> On Tue, 29 Oct 2013, Matthew Knepley wrote:
> > > Matt is the one with vision about BuildSystem dependencies so I'll leave
> > > it to him to comment.
> > I see fooling with dependencies as a good thing in general to simplify
> > things, but having not
> > much to do with what Jed wants. We can easily buffer till kingdom come.
> > What needs to be done is to overload write() for the logger, so that if no
> > file is open it buffers,
> > and then when a file is set, the contents get dumped in.
> The issue is: if there is an error in configure thats relavent [for
> which we want the user to send us configure.log from the predetermined
> location] - but this error happens before the 'file is set' i.e before
> PETSC_ARCH is determined.
I make some changes in 'balay/simplify-petscarch' and removed
dependencies for PETSC_ARCH/PETSC_DIR
However configure is still running it after programs.py and few other
things. [and I don't see any dependencies on it.
Matt, How do I specify that arch.py/petscdir.py should be run at the earliest?
thanks,
Satish
